ZeroTurnMan_com
- Jul 28, 2019
- 1
- 11
Just an example to save you money!! First off all the guys that own these big heavy commercial machines. When you hire the hourly help and just tell them how to mow the way you want it done, its not good enough. You have to make sure and let them know to always keep an eye on the gas. First thing the guy does is get far away from the truck where the gas is and runs out. then he drives the truck on to the property and fills the mower with gas. then he doesn't want to walk all the way back to the mower so he drags it with the truck back to where he is supposed to park. He released the brake thinking that would allow it to roll to where he was going. That's not how hydraulics work. You have to release the hydraulics by turning the lock counter clockwise. If you have 2 separate pumps, you have to release both pumps not just one. I you have a DUP series where one pump runs both wheel motors, you have to release both sides. NOT DOING THIS WILL COST YOU THOUSANDS!! Because you will break a wheel motor shaft when dragging it without the hydros not being released. Then when you get back where the truck or other piece of equipment used to drag it needs to be, you fire it up and engage the hydros and send trash thru the whole hydraulic system. Then it wipes your pump or pumps. So right there you have just done over a $1000 dollars of damage to the machine. Then a lot of guys think well its just a bad wheel motor. So they buy a new wheel motor and install it. Without dissembling every part that had hydraulic fluid in it cleaning everything. Then they fire it up and send trash into the new wheel motor. Then they determine its a Hydro pump. Then they install it without proper cleaning and wipe out a new pump and they still have a broke machine. Then they get frustrated and bad mouth the machine and sell it for scrap or trade it in on a new one. These mowers are heavy and get stuck or run out of gas and get dragged all the time. Just trying to stop you from wasting money!![IMG]
Keywords= John Deere's Part Number is TCA18087 John Deere Tuff Torq 10A056259 DUP10S DUP13S DUP17S Kanzaki Dixie Chopper Scag Tiger cub HUSQVARNA Yazoo-Kees Great Dane Exmark Lazer Z Toro Wright WOODS Bob Cat Ferris Walker Kohler Hustler Briggs KEES ZT MAX Cub Cadet Steiner diesel encore Super Surfer kanzaki dup-10A dup 10 a dup10a dup-13 dup 13 dup13 dup17 dup 17 dup17 Grasshopper zmaster Bunton Enforcer Snapper PRO Simplicity Stallion TURF TIGER PREDATORBOB-CAT 7 Iron Deck Lesco Kubota Ariens Tiger Cat Gravely Kawasaki 17 20 23 2527 HP Horse Power. · 325, 335 and 345 Lawn and Garden Tractors · GT245 Lawn Tractor · 737 Mid-Mount Z-TRAK · GX335 Lawn and Garden Tractor · X465 Lawn and Garden Tractor · 717 Mini-Frame Z-TRAK · 727 Mini-Frame Z-TRAK · 647 Quik-Trak Mower · 657 Quik-Trak Mowers · 717A Mini-Frame Z-TRAK · 647A Quik-Trak Mower · TONDEUSE QUIK-TRAK 657A ET 667A · GX255 Lawn Tractor, Mower Deck and MCS · TX Gator Utility Vehicle · TH 6X4 Gator Utility Vehicle (Gas) · X320 Select Series Tractor · X324 Select Series Tractor · X340 Select Series Tractor · X500 Multi-Terrain Tractor · X534 Multi-Terrain Tractor · Z445 EZTrak Residential Zero Turn Mower · Z810A Professional Z-TRAK · Z820A Professional Z-TRAK · Z465 EZTrak Residential Zero Turn Mower · X360 Select Series Tractor · 667 Quik-Trak Mowers · 757 Mid-Mount Z-TRAK · 727A Mini-Frame Z-TRAK · 657A Quik-Trak Mower · 667A Quik-Trak Mower · X530 Tractor Multi-Terrain Series with 54-inch Mower Deck
