Mower wont even turn over not sure if its a safety switch or solenoid ...
teachme
  • / Mower wont even turn over not sure if its a safety switch or solenoid ...
Hey guys i mowed last week with my mower no issues but went out this week gas'd her up and went to mow and nothing when i turn the switch it doesnt do anything. what is the best way to test the ignition switch. i am going to turn it on and manualy jump the solenoid in just a few minutes see if she will fire up just so i can mow before i go back to work but i didnt know what was the best way to test it like what trips it is it a hot wire going in or what thanks.
mechanic mark
Post your Simplicity model number. It's probably something simple.
Results Check out wiring diagrams, pages 48-50.
teachme
ok so i jumped the solenoid and it started there is no 12volt from the switch to the solenoid so its either the ignition or a safety switch. i have the express series.
mechanic mark
Check & reset circuit breaker between ignition switch and solenoid. Click on Results # 2 post page 48 wiring diagram shows circuit breaker.
Try this procedure to pin point the cause.
Electrical problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
