TylerFrankel1
- Feb 7, 2020
- 16
- 124
Hey everyone! I mentioned this in a post a while ago, but it was off topic for the post's original purpose, so I figured I'd make a new post about it.
I have a Troy-Bilt Bronco Lawn Tractor that I got free of the street for trash. It just had valves out of adjustment. I fixed that, now the engine runs like a dream. 18.5 Intek. I also replaced the sump gasket, oil and filter, battery, air filter, and blades. New fuel filter is coming. The air fins are clear well. Had to replace the starter gear because somehow the C clip got off and I never found it, or the spring/gear/washer on top. But it runs well now. Very smooth. Loud, because there's a rusted out hole in the muffler.
Anyway It had all the drive belts on it when I got it. The front/main belt was the most cracked belt I've ever seen. It ran for a good bit of time like that, however, probably an hours worth of time. I knew it would shred and it did. So I bought a new one and replaced it. The rear one looked acceptable, although I have doubts now.
After replacement, the mower works pretty well, but I feel like I'm getting some slipping. After long use one day, I lost nearly all forward power until I let the mower cool. Sometimes when it first starts up it has low movement power too. And, it has never felt particularly quick. My GPS speedometer from my phone measures 3-4 MPH when it should be more like 5, although I doubt the accuracy of the GPS. So I went and inspected the rear drive set-up and recorded what I found. Here's that video:
I found the variator pulley is slightly loose. I think that's my fault, because when I replaced the front belt I had it off and I may have overtightened and consequently stripped the bolts. To solve this I plan on drilling a third bolt hole and using a nut on the other side to actually get it locked in place (which is how Troy-Bilt/MTD should have done that in the first place).
I found that the transaxle pulley is not perfectly round. This makes no sense.
I found a slight groove in the variator pulley. Not severe but present
The middle plate in the variator moves freely
The idler pulley is noisy but spins just fine.
The belt in the back has minor cracks and may be glazed. I don't have a ton of knowledge here so I don't know if the belt is bad enough to cause these problems. I don't care if it's on the brink of failure, I'll run it until it dies, but if it's causing the slipping or power loss I'll replace it.
I didn't check the 2 idler pulleys underneath yet but if memory serves me correctly they spun freely if slightly noisy.
I found that the stupid belt won't come off the transaxle pulley unless the pulley is removed because there isn't enough clearance between the fender and the pulley.
The single little bolt that goes between the belt in the middle of the mower is in place.
So I don't know what the issue is. I'd guess it's a worn belt and the loose variator
Also, a different issue I've noticed is with the deck. It sways around a bit when the PTO is engaged. Nothing violent but noticeable. The Spindles are sealed so I can't really grease em. I would assume worn spindles are at fault, but they kick in/engage really quickly and smoothly and the mowing sounds/looks normal. I wonder if it may be because of my handy-work on the deck. It was rusted through, and I just bolted some sheet metal underneath where the holes were. The structural metal was fine btw. Perhaps the aerodynamics are affected by this and causing the swaying. If it's the spindles then unless it's gonna kill somebody I'll let it be and run the spindles till they die. I have a spare deck with spindles that may be good anyway.
