Mower deck Making the cut higher
RERICK56
I have a Simplicity Regent model1692354..The mower deck is 2 7/8 off the floor..When I was up north it was fine but here in Florida the grass burns pretty quick at that height. I have the adjustment up as far as it will go..Is there any thing I can do to make it so it will cut higher ?
benski
Maybe taller tires all the way around? I'd call Simplicty and ask them. If anybody would know, it would be the people who built it.:smile:
KennyV
Like benski said... larger diameter wheels... but you may find that the air flow under the deck will suffer if you get too high.... :smile:KennyV
WELCOME to LMF....
