I AM IN IRELAND USEING A HONDA HRX537 WALKBEHINDE MOWER . I REPLACED THE AXEL SEALS ON THE HONDA AS THEY WERE LEAKING , AFTER REPLACING THE SEALS I AM NOT SURE OF THE PROCEDURE OF REPLACING THE LUBERCATION ,OIL IN THE HYDRO TRANSMISSION . I AM NOT SURE OF THE AMOUNT OF OIL TO ADD TO THE HYDRO . IS THERE A AMOUNT TO USE AS IN A AUTOMOBILE ? THERE IS NO DIP STICK SHOWING THE LEVEL TO FILL THE OIL TOO .I AM NOT SURE IF YOU OVER FILL THE OIL IF THIS WILL NOT ALLOW THE HYDRO . TO OPERATE AT IT FULL SPEEDS ?
PLEASE IF ANYONE IS ABLE TO HELP PLEASE LET ME KNOW .
