Manhattanjim
- Apr 23, 2017
- 1
- 1
Hello All,
Cleaned the gas tank, added new fuel line and air filter. Filled with fresh gas. Runs excellent for 20 minutes or so then cuts out and will restart only to continue to cut out at progressively shorter intervals. I drain and clean the fuel line along with the gas tank with same results. Can you suggest anything other than moving into a condo?
