John Deere Ignition Swap
Trog182
can you bypass the circuit board under the dash and rewire unit like the good old days? Mower is not worth putting a bunch of money into
tom3
Depends on what engine and how old. Some of them are standard mag and coil with flywheel magnet trigger. Cut the ground, turn the motor over and it runs. Some have the voodoo optical triggers and all kinds of high tech useless garbage.
