Ranch.Hand
- Aug 6, 2018
- 1
- 7
There’s very little tension on the belt when engaged. It’s so loose the blades do not engage.
The mower is only 3 years old. Gets used probably three times on just over an acre each time per year.
The belt is in good shape.
The real confusing part... the L bracket for the cable and spring to provide tension on the belts is welded to the mower chassis, instead of bolted like the manual indicates.
Help? How do you adjust the engaging points to provide tension to the belts?
Basically, (B) is welded, and there aren’t any (A) parts in the attched image from the online manual.
