JD 120
Jinglesj
PTO switch locked in neutral position on toggle style switch
Richie F
Info of the machine please.
Model and serial number.
Jinglesj
Got it going. Now working on my daughter John deere gx75
tom3
Is this one of those that you pull up on to allow the switch to move?
Jinglesj
Yes it is. Was seized up, I pulled it off and lubed it with graphite. Glad to say is working great now!
Jinglesj
I'm now working on a John Deere gx75 of my daughter. Seems to have ( I call) dead short. Keeps blowing fuse every time you turn key to start it. Replaced the ignition switch but to no avail. Gonna start chasing down the short tomorrow.
Richie F
Blowing a fuse is a short.
When the fuse blows is it just when you turn the key on or when you go passed that and try to use the starter ?
Replacing the switch isn't the problem, it's down stream from that.
Does your ignition switch have 5 terminals ?
Jinglesj
I'll check for sure tomorrow and get back to you on it. Been busy with grandbabies today
