Ignition module needed
Bjbert
Does anyone know were I can find an ignition module for a model #7226 lawn boy with a D600 engine. The original part # 683321. Thank you.
Scrubcadet10
Moderator
Staff member
There's a few on ebay for $70+....... the part number was changed to 94-7418 so that might give you another option to search for.
FuzzyDriver
Did you try cooking it yet? For no good reason that I can think of, some of them can be returned to working order by heating them up.. You can take it out and put the module in the oven at a fairly low temp (I dunno, maybe 250?) for a while. I fixed one by simply blowing it with a heat gun until it got good and hot. Hair dryer might work, too. Worth trying...
Wayne361
They pick up moisture. Baking removes the moisture
