Hi guys,
MTD 13AI617H118 (2002) 46" 21hp
The other day while I was mowing, the double engine pulley actually sheered in two. Yes, the lower pulley (pto) broke away from the upper pulley (drive). Fortunately nothing else appeared to be damaged, and although the blades stopped immediately, I was actually able to drive the mower to my driveway and look at what had happened. This established that the drive system was operational as normal. I ordered the double engine pulley... it came in... and I prepared to replace.
Of course before dropping the old pulley in order to replace it, I had to relieve the tension on the drive belt, which I did according to the manual instructions. I should have taken a pic of where the Idler Extension Spring (732-0429A) connected... arrggghh. I know it connects to the furthest outer hole on the Double-Idler Bracket (683-0251), but then to what? The diagram shows it connecting to a Hex Cap Screw (710-0344), but when I connect it to that I it doesn't create enough tension for the belt to engage (i.e. the mower goes nowhere)! I've confirmed the belt routing, etc. and do not know what to do.
Please help.
Thx,
Mitchell
Please help.
Thx,
Mitchell
