I just restarted my engine after a camshaft and push rods replacement and it works fine. The problem I have is it won't idle, just run full speed but if I engage the blade (it's a Troy Bilt 18hp riding mower), it will let me control the engine speed and would probably attempt letting me set it to idle.
Not sure what I have done wrong. I set the governor all the way to the right (clockwise) when the engine was upside down after I reinstalled the oil pan.
Thanks for your help if you have any advice.
