I have a John Deere L110 w/ a Kohler 17.5 HP
realtr1963
Never had a Starting problem, until now. I couldn't get it to start.I put a new Fuel Filter & Spark Plug. I put it on level ground, and Blew out Gas Line. I wasn't getting Gas to the Filter. I Blew in the Hose, toward the Tank and received Prime. It would run close to a Hour or when I was on a Steep Incline. I've done this several times. I need Help!
Please!
Please post your engine model numbers
realtr1963
cv-491. Is this want you need?
Junk4um
Have you checked whether your gas cap vent hole is clogged? I had the same frustrating problem and was about to replace the fuel pump when I noticed that the vent hole on the cap was clogged. Naturally, this created a vacuum inside the tank causing the fuel pump to starve and the engine to quit. Cleaning the hole solved my problem.
reynoldston
Are you saying this only happens when you go on a steep incline? Maybe something in the fuel tank is plugging the fuel outlet.
