Hustler 4500 electrical issue
Justcar
Hey I'm working on a hustler 4500, not sure the year but it is older. I have a no start no crank issue and don't know much about these mowers. These are the new parts: battery, ignition switch, starter relay, and the 5 pin bosch relay under the seat, and new 30a fuse between alternator/starter relay/ignition. The starter will turn if I hook it directly to the batter so it's ok. On the starter relay the terminal from the battery has good power, but the other main terminal has none. When key is in on position the warning lights to not come on as they should. I am fairly sure it is one of the safety switches for the startup procedure but I can't figure out what the next step to troubleshooting is. Any help would be much appreciated.
