HRX217K2HXA adding hydrostatic fluid?
LanghorneNeil
Hello all, have a hrx217k2hxa that I think needs some trans fluid added. Just replaced all the rear bushings and dust covers and neglected to check the fluid while the trans was out. I have a problem where the drive is slow and noisy when cold and gets slightly better after it warms up. This problem was there before I did the repairs. Can I just turn the mower upside down and add hydro fluid with a syringe through the screw hole in the bottom of the transmission? If so, do I just fill it up to the top? Thanks for you insight....
  • Like
Reactions: de3
