HRR216K3VXA starts, then dies
coldje
The timing belt broke in our HRR216K3VXA. I removed the engine, opened the case, cleaned it up and replaced the timing belt. After adjusting the valves, and reinstalling the engine, adding oil and gas, we tried to start the mower with a new carb we installed. With starting fluid, it will run for a few seconds and die. I installed the old carb and same thing.
