Don't seem to be getting any response from my starter on my HR214 SM. I've done some basic troubleshooting without any luck. To test the starter -- can I just put 12V across these to see if the solenoid will kick the pinion gear up to engage the flywheel? The pinion gear moves freely when I manually rotate it up to the flyweel. Any advice on how best to troubleshoot would be appreciated. Thanks.
Please note I don't need the starter to use the mower -- it starts first pull using the rope. I just have never had an electric start mower before and like the novelty of it.
