HR 215-AB LEAKING OIL
jackcu
Ok while trying to blow air thru the fuel line back into the tank to clean out some trash. I accidently blew about 20 pounds of air into the intake line and hear a POP which I assume was a gasket of some sort. Now when running oil is leaking out and seems to be coming from some where around the top of the motor. That would be the top side of the motor as it sits horizontally on the deck I am not really sure where it is coming from. I pulled the valve cover and that gasket seems fine(plan on replacing it anyway). Any one have any ideas on what gaskets/seals I need to look at? I cant determine exactly where oil is coming from. I do know its not coming out from the bottom seal of the mower nor is it coming from the dip stick holder. The model number is MZAM-6038191 SXA*. Numbers in the valve cover are ZG9 HM 1.
Any help would be greatly appreciated. thanks
reynoldston
Sure sounds like you might of popped a seal or gasket out of place?
