Honda push mower trouble!!
07drummerboy
Honda push mower it starts and runs for about a minute and then cuts out dead!
Any ideas on what would be the problem??
Most likely something to due with the carb. either choke not working properly or the carb may need cleaned.
gimmodog
pull the bowl off the carb, clean the debris out of it. There is a small hole directly in the center of the bowl area on the carb (where it pulls the gas into the carb from the bowl) this gets gummed up and clogged. Take a small wire and run it up and down that small hole to clean it out then put back together. Add some seafoam to the gas to clean out the gasoline gum in the carb. Hole this helps. Stan
