Honda GVC160
pokesr
I'm taking this Honda GVC160 Engine off of a Troy Bilt Power washer in which the pump went out and want to put it on a GoKart frame for mygrandson, the problem is that the exhaust faces the back of the seat so I'm trying to find a flange to fit where the exhaust port is and then weld a pipe to it so I can redirect the flow of the hot gases from the engine, I can't seem find one, can anyone out there help me?
thanks
Go to your motorcycle breakers.
Should be hundreds of old pipes there that will fit.
But remember to take the engine , old exhaust or even the cart as is.
Most wreckers will take a look and know what pipes will work.
Downside is most wreckers charge arounf 1/2 new price & motorcycle exhausts are very expensive.
