Hello everybody,
I need help
My new lawnmower is not running as expected.
I have used it flawlessly 4 times (4 hours).
Last time I used it, after 30 minutes of running flawlessly, the engine RPM fell and now it's only running at low RPM.
Now, each time I try to start it, it run at very low RPM
It has a Honda GCV145 engine.
The lawnmower is very simple without any throttle lever.
What is weird, if I move the governor with the hand, instead of lowering RPM, it increase RPM.
The governor behavior is inverted.
Is there anyone that can understand what happening?
If you have any idea thanks for your help
I need help
