I've loved my little generator until this year. No spark. This is what I've tried so far... removed casing and exposed the coil and flywheel. Everything looked good. Cleaned off the small amount of rust on the magnetic flywheel pickup (has pretty good magnetic pull). Checked the air gap looked good. If I ground the plug I can feel just a small amount of shock with my finger on the end of the plug when I spin the flywheel. Checked the oil level as it has an alert system. I got one visible spark from the plug in all the checks I did.
I would be happy to purchase a new coil if I new for sure it was the problem, but, I have also read people who have had the same issue and replaced the coil with no success.
Is there any way to check the plug end of the wire for a short? I am assuming that if I am getting any sort of jolt the wire should be intact?
