HONDA EX650 GENERATOR NO SPARK
STEVES
HI, NEW HERE, STARTED SMALL ENGINE & LAWN EQUIPMENT REPAIR PART TIME 2005 / AUTO MECHANIC BY DAY / HAVE A HONDA EX650 WITH NO SPARK / CUSTOMER INSTALLED NEW COIL & THEN BROUGHT TO ME / STILL NO SPARK / MAGNET SEEMS STRONG / TRIED DIFFERENT GAPS / ANY IDEAS??
THANKS
STEVES
twall
Caps lock still stuck? :laughing:
jeff
Have you checked the ground wire for being pinched or bare spots?
STEVES
YES, COIL HAS NEW WIRES & ALL IS UNPLUGGED
jeff
Then I would try another new coil.
STEVES
THANKS, WAS THING THE SAME. THE COIL OHMS OUT, BUT NEW IS NOT ALWAYS GOOD:frown:
STEVE
STEVES
BETTER TO SEE WHAT I'M TYPING:confused2:
KennyV
But NOT better to read...
I try to type for those that have to read it...
I would explain that caps are generally used for emphasis in most forums, but I'll bet you have been told that before... :smile:KennyV
BKBrown
Try to go advanced and change the font and size until you can see it better :biggrin:
If you are using internet explorer - up under View - you can change text size so it is easier to read on your screen. :thumbsup:
