Ferris 2561T Zero Turn, worked perfectly fine. One day I tried starting it, it started as usual ran 2-3 secs then shut off. I check the oil, it was low. I added oil. Started right up and fine since. I noticed that the machine started creeping lately, so I adjusted the control arm. Went to start it and it started ran for 2 secs and shut down. Oil level is fine. Just changed oil and filter last week. Could the oil sentry sensor be shot? If so, where the hell is it? Can't find it. Could it have something to do with the control arm adjustment? Is there a sensor in the tranny that say unless that arm is perfect it will shut off? I checked the lever switches, held the seat with down to start it, same thing runs then dies. what did I miss, carb is clean, fuel filter is new. Help!!! Grass near 4"!!!:confused2:
Also dropped carb bowl, cleaned it out, looked good. Bloew out fuel line and checked float, worked perfectly. I'm thinking its a safety switch but have not idea where to look.
