Grass is getting long....
Clarkesville Ed
My Murray riding mower is about 18 yrs old. I finally (had to) replace the ring gear on the flywheel. Got it all back together and gave it a quick test start....starter worked wonderfully. Shut it off to finish up, now it won't start! Sounds like it's not getting any spark. Not sure, I am nor
Tinker Ty
Check all your harness connections. Sound like one is unplugged. Also check your grounding. Good luck.
Clarkesville Ed
I've looked over soon the wiring...looks intact. Grounding? What should I be looking for...?
Also, if my sperm plug was out on the bench while all this work was being done, could the spark plug getting banged around have caused a problem?
