Post what engine it is, brand, type, H.P. ect... most generator engines have a tapperd shaft, a long bolt runs through the center of the rotor shaft & threds in to the tapperd end of the crankshaft, you may have to make a tool to fit over the rotor shaft of the dismanteled generator which will turn the rotorshaft with the engine locked with a piston stop or other means of stopping the crankshaft from turning while gently turning the gene rotor.
