FX691v not feeding fuel to right cylinder?
Champ
Will run on left cylinder but not right. If we mist fuel into carb it will run on right?
mowing and all good and then Felt a loss of power. Appreciate any insight. Thanks.
IF it works when you spray fuel into the carb then the carb is the problem
if it has a 2 barrel carb then it has individual jets for the left & right so I would look at the right side jets.
