Fuse blowing
Yvonesullivan76
I have a Z225A and I mowed with it and parked it .. went back the very next day to crank and it keeps blowing a fuse everytime I turn the key.. any advice on troubleshooting
Tinker Ty
Get your meter out and start looking for dead shorts. Unfortunately, you need to dig when it comes that. Have you replaced the fuse and does it blow right away? I would say replace the fuse and see if it blows right away or when the motor is running or after you shut it off, etc etc. Look when the problem happens and then start chasing. Good luck.
