Where can i this partBig Dog Alpha has a problem that is breaking the hydro mounting brackets. They came out with a kit to fix the problem. If you could get the axle mounting brackets they are really heavy duty and you might be able to use them to fix your mower. They bolt on the frame.
Thank you All help is apreciatedBig Dog or Hustler dealer. Fits the BD Alpha and the Hustler Raptor. BD will be red and Hustler yellow. You will need the bracket out of the kit. It bolts to the frame with three bolts not two like came on the mower. Give me a day or two and I can look it up for you after the 4th.
