Flywheel clutch stub shaft
Webn237
Anyone have access to a used Grasshopper 824637 clutch stub shaft? Came off of a 718D or 721D. Need one for my D600 engine. Thanks
Webn237
I found another part number also. 604189
Rickw
Try some local dealers. Most have salvage machines out back.
gsim
You might try eBay. Be sure to use original Hopper part number from your op manual, or call dealer to get part #. Lots of vendors on eBay include original part # in their heading. BE SURE TO POLISH IT AND TO APPLY NEVER SEIZE OR WHITE LITHIUM GREASE TO IT BEFORE REASSEMLY!!! Can save a ton of labor if later you need to R&R the PTO clutch.
