Ferris IS700 ZTR 2012 Sindle issue
Lbutler225
I bought 3 new spindles for replacement. Just can't get the old one off. The wheel will not come off. I removed the big nut on top and the spacer and even torched it. I can't get to the small bolts that are under the wheel, So I slid a wrench underneath the wheel to hold the nut so i could unscrew the 4 bolts that were holding the spindle. All worked good . This would save me from damaging the wheel. The wheel would be resting on the deck. Now my spindle is dangling. I figured that now I could hammer the top of the bolt and the spindle would fall out. It just isn't happening, I have watched every video on you tube to see if i was doing something wrong.....I am stuck, Any advice would be appreciated before i beat the living crap out of the top of the bolt....
Lbutler225
Never mind. I beat the hell out of it. It came off
