I have a 2001 Craftsman. 917.275041. I am awaiting the 174509 Electric Clutch. My original almost was a short. It was only .2 ohm, when it should have been between 2.3 - 3.4 ohm. the Coil in the clutch was essentially shorting out the battery and killing the engine when I engaged the blades. I melted a PTO switch before I found the problem. Anyway, I cannot find anywhere (1) how much I will need to torque the mounting bolt on the clutch, and (2) what size gap do to I set the clutch to with a feeler gage I assume. My manual only says that these settings are critical and I can ruin the clutch if I do it wrong. The dang clutch costs $216 and I can't afford to screw it up. Any help would be appreciated.
Over grown in Texas,
Eyeball
Eyeball
