Export thread
cub cadet recon 48
#1
A
an-2o
i was wondering if anyone knew the spec's on the white wheel motors that come on the recon and tank 48? i found a site that sells them a lot cheaper than from cub cadet called surplus center but i don't know the cubic inch of the white motors that came with the recon. any advice would be much appreciated, thanks
#2
BlazNT
BlazNT
If you could get us the numbers off the drive we could get you everything you want.
