Cub Cadet mower blowing oil
jb4249
I have a Cub Cadet mower SRC 621 with a Kawaski FJ180V engine. It is blowing oil out the carb, so bad it is dripping. When I pull the oil filler cap it is like a smoke stack. So I must have too much crankcase pressure, but why. Any hints.
Thanks, Ted
Is the oil level normal and not high. Does it smell like gas. Have you tipped the mower on its side recently.
jb4249
It is filled to proper level. I have not tipped it but was not the one cutting with it when it started. I will need to smell the oil that is coming out
