crank case loose
ed fender
replaced crank case cover and gasket the timing marks were right on adjusted valves but timing is still off some where sv600
Tiger Small Engine
If the camshaft timing mark is aligned correctly, and the flywheel key is not partially or completely sheared, then the timing on engine is spot on.
ed fender
that's what i thought as well but something somewhere is not being cooperative i thought maybe i was over looking something it is puzzling
hlw49
FW bolt torques to 65 fl lbs for M12 bolt and 49 fl lbs for M10 bolt.
VegetiveSteam
What's going with it that makes you think it's out of time?
I suspect there is a ACR issue not releasing compression to crank the engine. Have replaced the ACR on the camshaft a couple times, but ends up being a temporary fix. Have also had to replace the cam gear in conjunctio with the ACR but even that can still result in intermittent issues.
VegetiveSteam
There is an intake timing mark and an exhaust timing mark on each cam gear. Could you have possibly lined up the marks on the wrong sides?
