Craftsman Z6000 HYDRAULIC FLUID CHANGE
BBOB662
What is the procedure to change HYDRAULIC FLUID/OIL in a Sears Z6000 zero turn mower? It has very little pulling power and is 4 years old.
BlazNT
Your mower has EZT trans and they have to be removed from the mower to change the oil. They are "sealed" and really do not need the oil changed. I changed mine because I buried them in a creel and they took on water. The most likely issue will be the drive belt. You should change it first and see if that fixes your problem. Make sure to take lots of pictures before you remove anything. This is very important. Link to your manual for the drives so you can change the oil.
http://www.hydro-gear.com/service-and-repair-manuals/
Scroll down to ZT-2100, ZT-2200 (EZT) and download it.
BBOB662
Thanks. It goes about 50 feet and then doesn't want to pull. Belt?
BlazNT
Yes, belt in my opinion.
