craftsman walk behind trimmer replacement blades
agmccall
Hello All
I have a craftsman 22" walk-behind trimmer that I purchased last May at Lowes. one of the blades broke. Unfortunately, it is the blade that holds the string so now the whole unit vibrates. I would cut the blades down but the one that broke also broke oft the part that holds the string.
I can not find this anywhere. Lowes was no help at all. I went to a local lawnmower dealer they found the part number but could not find the part anywhere, could not even find a reference to it on the net. They could not find out who actually manufactured the unit. I am at witts end as I now have a $350 piece of equipment that runs great but the breaking of a $3.00 part has now been rendered useless.
Any help would be much appreciated
Blade part number 101036 Unit Model Number CMXGCAQ108493
"EDIT..I had the model number wrong, corrected"
Al
agmccall
Thanks for the reply. I finally found out, from craftsman, that the company that makes this trimmer is out of business. Craftsman is going to give me a full refund for the trimmer. If anyone else has this problem contact craftsman. They will require that you have the original receipt,
al
