So here is a simple but maybe stupid Question, when servicing a snow blower gearbox (any brand) and needing to replace the factory grease that's inside, what is more used/recommended?
I've been searching around and been getting many mixed answers, The owners manuals on some recommend a Shell Alvania grease which i find is NLA an replaced by a Shell Gadus s2? pretty expensive stuff, and for ariens they have their own special brand lube, ive heard some people just packing it with your typical ball joint grease, some use 90W gear lube, or even a "00" grease which from doing research is a close EP lube to the Shell Alvania.
ANY Input or recomandations?
Thanks
Thanks
