Considering X320
JWK
This is my first post.
I currently own a GT225 and am considering a X320 with a 48" deck with mulching. I am concerned about the K58 transmission in the 320. I do have a sprayer and spreader I pull behind the mower. I have about 1 acre to mow. Should I consider the X500 instead of the X320.
I own a 2012 X320 and I really like it. I have a very large yard (3+). I have hauled heavy loads with no problem with traction. Because I have no hills and do not use it for snow removal, it suits me just fine. :thumbsup:
PJ
Bigger is alway better sir! Will the X500 be able to access everywhere you need it to go?
Good luck with your choice
PJ
JD X485SE
Not sure if you have purchased yet, but the X320 will do everything you mention without a problem. I pulled a core aerator and 600# roller with mine and it never complained. The diff-lock on an X500 is a really nice feature, but from your original description, you might not need it.
