CMM1000 Charger/Connectors
cjl
HI ! The molded connector on the end of my AC to 24v wall charger (B&D 242901 discontinued) is damaged beyond repair. Ideally I'd like to identify this connector and replace it but so far haven't found an exact match with Molex or TE websites. Alternative is to replace the connector on the mower (already have the cover off) with any plug & socket pair. Wonder if anyone has ID'ed the connectors that were used or has come up with some alternative connector pair that fits ? Thanks for any suggestions/comments! P.S. I have read inputs about replacement chargers but seems i might need a mod to the CMM1000 Type 5 charging circuit to accommodate a replacement charger (B&D 90556983) plus don't want to spend ~ $50 for a new charger that might or might not work properly.
gfp55
Maybe you could check Ebay or craigslist. I don't know anything about those things. Sorry I was not more help. Good Luck
