Briggs and Stratton Carburetor Replacement
cdb
Needed to replace Briggs and Stratton carburetor on John Deere Lawn Tractor - float sticking. Purchased replacement carburetor, however, the original used a lever that pushed a rod forward and engaged the choke. When the lever is reversed, the rod disengages and the gate springs back closed. On the replacement part purchased from B&S - #791886, the choke is manually operated.
I contacted Briggs and Stratton and was told that this is the correct replacement part. However, there is not a spring on the replacement unit. Quote "it is up to the customer to create a workaround as we no longer make a specific part for this engine."
Has anyone run into this situation? Briggs and Stratton also said they do not make any adapter kit?
Thank you.
Engine: Briggs and Stratton Model 28Q777 Type 06662E1 Code 98031620. Gravity feed carburetor (no pump)
will the choke assembly from the old carb fit the new carb.
jcobo
Engine: Briggs and Stratton Model 28Q777 Type 06662E1 Code 98031620. Gravity feed carburetor (no pump)[/QUOTE]
Recently I had to find a carb or a kit to replace/rebuilt one.
I ran several searches via Google and I hope these links will work for you.
Key words >>>Carburetor exchange
carburetor exchange - Google Search
Key words >>>Carburetor interchange list
carburetor interchange list - Google Search
carburetor interchange - Google Search
View attachment Carburetor.doc
Also look on the top of the carb for a disk with numbers on this will help you identify the carb easier than going by make model etc of the mower.
If you are really brave goggle those numbers with the maker of the carb.
Good Luck
Have Fun
John
RobertBrown
See if John Deere has any parts that will help. If not I guess you have 2 choices, snd the carb back and fix the float or make the new carb work.
If you need help with choice #2, post some pictures before you mount the new carb and maybe we can offer some suggestions. seems like a manual choke might not be a bad thing.....
It seems odd to me that you can not get the replacement part, so... no I have no experience with this problem
cdb
Unfortunately, no. It is molded plastic - would break it to remove.
mullins87
Shoot, I'd just install a manual choke knob and consider myself lucky.....I've always hated those "automatic" chokes.
