Blade clutch not working voltage issue
Zrafferty
I have a wright standard that clutch won’t work.
I have tried a new switch tested fuse and even energized clutch through wire to battery.
When I used wire I hear the click but don’t get a click any other time what else should I look into ?
sgkent
get a schematic for your mower then follow the circuit to see where the circuit is failing. That is what anyone would have to do.
Zrafferty
I do Gonna look back through first time o had to test clutch with battery just started going back through looking for quick ideas to check
Zrafferty
After reading checked over got blade’s working
Was a mix of bad relay bad pto switch and wire harness but problem was fixed
Have bothered to check the current draw of the PTO clutch?
