Billy Goat MV601 with Briggs and Stratton PXi850 engine won’t start.
Ljames555777
  • / Billy Goat MV601 with Briggs and Stratton PXi850 engine won’t start.
I have a Billy Goat MV601SP lawn vacuum that won’t start. The engine is a B&S PXi850. The machine has a cable connected choke and a separate choke lever on the engine. The machine is brand new and has never been started. I don’t know if is a choke setting issue or what. When I was taking the machine home from the dealer, it was raining. Has new fuel and oil.
Any assistance in getting the machine started would be greatly appreciated. Thank you.
mechanic mark
Inspect air filter for being wet, let it air dry. Post Model xxxxxx, Type xxxx, Trim xx, Code xxxxxxx from engine.
Ljames555777
Here is the data plate information for the B &S engine on my MV601SP:
Model Year: 2022
Displacement: 190 CC
80106448
Exh Family: NBSXS.1901 VS
ECS: EM, CN
Evp Family: BSXCNVOO7
NBSXPNHEQNV7
Eu
e52016/1628*2016/1628SYA2/P*1038*00
EPA Emission Compliance Period: 250 hrs
Most Clean
]10 Least Clean
r index
DOM.
July
2022
Serial #:
2207203632678
Model Number:
123P020018F1
Ljames555777
The Air filter was dry. There is a choke and an engine speed controller on the lawn vacuum.
Thanks for helping.
Take the unit back to dealer as it should be a warranty covered issue.
mechanic mark
Thanks for posting information. Read Operators Manual thoroughly & see if you're missing something, give it a try. I agree with StarTech, return Billy Goat to dealer because of no start issue, under warranty.
Ljames555777
Thank you to all for your very valuable advice. I’ll be taking it back to the dealers in the morning. With let you know what the diagnosis is whenI pick it up.
