Battery voltage
Scrubcadet10
Moderator
Staff member
I want everyone's opinion.
What is the ideal Voltage for a brand new battery that is charged 100%?
What voltage range would you consider a battery 'good' ?
Curious as to how many people have different answers.
No answer to this.
The chemistry of plates & pastes varies and will give slightly different numbers
A strait lead acid cell is 2.10 V
it can be overcharged to 2.7 V
A lead/silver cell is 2.2 V
it can be overcharged to 2.75 V
The idea of overcharging is to create a higher potential which slows down the self discharge rate.
However the cells will revert to its base voltage the instant any current is drawn.
Thus a good battery should be above 12.6 V fully charged
BEcause of the variability batterys USED to be checked by measuring the specific gravity of the electrolyte and not the voltage at the terminals .
Richard320
The test for a battery is done with a load tester or a digital battery tester, not with a voltmeter. A lead-acid battery should show no lower than 12.6V before you test it.
Voltage doesn't tell you much about the battery once it's been in service. Half the lead could have vibrated off the plates and be piled in the bottom of the cells where it does nothing. The acid may show good with a hydrometer .You might even show good voltage, but the amperage is gone.
Born2Mow
What makes the battery so strange to deal with is that's it's the only electrical device that deals with chemical reactions. Every other device's behavior can be accurately predicted at any time knowing voltage, resistance and current. But not the battery !
One of the strangest behaviors is the "surface charge" effect. Surface charge is when excess electrons pile up waiting to leave the battery. Sort of like commuters that jam the platform when they expect a train. If you simply look at the 100 people on the platform, then you might guess the entire station must have a total of 1000 people, when it's really only 120. Surface charge does the same thing by giving you an incorrect "picture" of what's going on.
And that's what "load testing" does. It drains off the excess voltage so that a more realistic view of the battery condition is obtained. There are standards for load testing, but you can set up your own standard using an old headlamp bulb. Try connecting the bulb to the battery for exactly (say for instance) 2 minutes. THEN take a voltage reading, and that reading will be far more accurate. The bulb acts as a "load" and burns off the excess energy. A "good" battery should end up no lower than 12.3V, but might have originally read 12.7V just off the charger. (Just be sure and use a high wattage bulb, not some dinky 5W tail lamp bulb.)
If you have a 12.7V battery just off the charger that dips to 12.0V after being "loaded" you know that's the exact same thing the starter motor is doing, so the battery is no good.
Hope this helps.
