Battery goes dead after one week of storage between cuts
thamajik1
  • / Battery goes dead after one week of storage between cuts
I have a John Deere LA100 Lawn tractor. Bought it new in 2005 Worked good for two years, now every time I put in garage between cuts for a week or two the battery is dead. I have to jump it to get started. Now when running it is charging, running lights are fine when running. When not used for that short time something is draining the battery. Has anyone had this problem or know of a fix would be great. Someone said might be a Diode in the system.
mac
If you want the quickest fix, disconnect the battery each time after you mow.
Lancslad
How old is the battery? If it goes dead its usually history. I find that mine last 3 seasons tops. Time to spend $20 at Walmart!!
Too reasons for batteries going flat
1) bad battery self discharging
2) faulty regulator attempting turning the alternator into a motor
Doing as Mac advised will allow you to determine which one is causing the flat battery
Rocky J
You bought the mower in 2005 , is this the original battery?
jd 300
You must have a power draw check the electric blade clutch or anything that might stay warm.
4getgto
If this battery is much more than a year or two old it could very well be the battery. Have it check....
I know people get 2-4-6-8 years out of some BUT some only last 6 months.
There a reason most only put a 30-90 day warranty on them.
thamajik1
Thanks I appreciate it
