B&S Model 92202 3.5 HP Fuel Tank?
seagiant
Hi,
Trying to get a 3.5 HP up and running on a Edger.
Does this tank have a inside compartment for the short pick up to pull from for the pulsa jet carb???
If you have a pulsajet carb it’s more than likely there is a small auxiliary tank inside the main tank. It would be much easier to answer your question if you would supply us with all engine numbers.
seagiant
Hi,
Thanks!
Model 92202
Type 1242 E1
Code 971003FA
If you have a 2 or 3 quart tank you will have and auxiliary tank. Unsure about the 1 quart tank.
seagiant
Hi,
Thanks, It is a 2 quart.
Got a strong light and can see where it broke off!
Looking for a local used part now!
seagiant
Hi,
I don't see anything available new?
How are you guys keeping these older motors going as far as parts?
seagiant
Hi,
Well...Called a Dude I know that owns a Lawn Mower Shop and asked about a used Tank in the Junk Pile.
He's busy of course so went over and found a B&S Model 91212, Type 1319 E1.
It was on an MTD Edger missing 2 wheels, and looked pretty good, asked what he wanted and he said, take it!
Sooo...Going to clean it up and have a look.
If I can get it running, will put it on the more stout McLane frame and call it good!
I take it, that this Engine is a "Kool Bore"?
