Northshoredoug
- Apr 24, 2022
- 4
- 16
Ok...rookie mistake, I'm into this 23hp 44C777 for other reasons and completely forgot to make a note of the timing mark.
The cranks gear is clearly marked at the keyway with a dot, but the cam has 2 choices almost across from one another, a dot and a straight line.
If I line up the dot with the crank and rotate, the other line is off one tooth- and vice versa , put the line with the crank dot and then the dot is off one tooth.
50 - 50 chance one of them is correct but which one? nothing mentioned in the repair manual except to line up the marks.
Thanks for a great forum, I learned alot reading here.
Doug on the Northshore of Oneida lake in Vienna, NY
