Hello. I need some help. I have a Ariens YT11 (model #935009, SN 007800) that I can not get to turn over. The mower was given to a friend who worked on it and he couldn't fix it, so he passed it on to me. When I turn the key, I get nothing. I have checked and I am getting 12V to the solenoid, but nothing beyond that. I swap solenoids from a mower that works. Same problem. Same thing after I swapped ignition switches. The starter will turn if I use a screwdriver to jump across the solenoid. I figured it could be an interlock switch. According to the manual, there are interlock switches but the manual only show the electrical diagram. It does not show where these switches are located and I cannot find them on the mower. If anyone has a manual that shows the location of each of the switches or could tell me where to look, I really would appreciate it.
02707800 Interlock Switch
02913100 Neutral/Start Switch
53510500 KIT INTERLOCK MODULE
