Additional mower function
Tenin
Hello, I have a slightly unusual question. I was looking for information about the additional functions of tiller, many are not surprising, but from this article learned about the fact that it can be used to mow the grass. I have a Hyundai T2000E. I went to all the familiar shops with outdoor equipment but have not found anything like it. Can someone suggest where you can find a choice of such equipment?
YEs, no, maybe, perhaps.
Some one with enough functioning brain cells looked at a flail mower are saw a similarity between it and a rotary hoe.
Now because all of the acid they took in their youth has heightened their imagination and destroyed their powers of reason & deduction they decided that the one can be used for the other.
So set it at 1" above the ground & see what happens .
One thing that will not happen is the grass ending up being cut.
Even if you sharpen the blades razor sharp it will still not cut your grass.
