6HP Briggs Wont Stay Running
davbell22602
123K02
0541-E1
05080957
Cleaned and rebuilt carb. Still stay running unless I keep hitting the primer bulb to keep it running. Bad primer bulb?
Ifixdit
123K02
0541-E1
05080957
Sounds like its starving for fuel. Check and make sure you reinstalled the carb to air cleaner gasket. Sometimes if you add a second gasket it will solve the problem. Good luck!
Have the carb ultrasonically clean and rebuilt with a new needle/seat kit.
